configure inline-power classification
[802.3af | 802.3af-high | 802.3pre-at | 802.3at | 802.3pre-bt | 802.3bt-type3 | 802.3bt-type4] ports
port_list
Description
This command configures PoE port-level classification
power-up mode for Extreme Networks PoE devices that do not support 802.3bt when
connecting to switches with 60W/90W PoE ports. ExtremeSwitching platforms
support per-port basis configuration.
Syntax Description
classification |
Classification power-up mode. |
802.3af |
IEEE 802.3af 15W mode. |
802.3af-high |
IEEE 802.3af 30W mode. |
802.3pre-at |
IEEE 802.3 pre-at 30W mode. |
802.3at
IEEE 802.3at 30W mode. |
802.3pre-bt |
IEEE 802.3 pre-bt 4-pair 60W mode. |
802.3bt-type3 |
IEEE 802.3bt Type 3 60W mode. |
802.3bt-type4 |
IEEE 802.3bt Type 4 90W mode. |
ports |
Specifies the port. |
port_list |
Port list separated by a comma or - . |
Default
Depends on the maximum classification level supported by the platform. For
example, one switch can have a default classification level of 802.3bt-type4, while
another a default classification level of 802.3at.
Usage Guidelines
Use the specified power-up classification instead of the default classification based
on port type.
The following command displays all classification options:
# configure inline-power classification ?
802.3af IEEE 802.3af 15W mode
802.3af-high IEEE 802.3af 30W mode
802.3at IEEE 802.3at 30W mode
802.3bt-type3 IEEE 802.3bt Type 3 60W mode
802.3bt-type4 IEEE 802.3bt Type 4 90W mode
802.3pre-at IEEE 802.3 pre-at 30W mode
802.3pre-bt IEEE 802.3 pre-bt 4-pair 60W mode
This command was first available in ExtremeXOS 31.3.
The 802.3af, 802.3af-high, and
802.3pre-at options were added in ExtremeXOS 31.7.
Platform Availability
PoE
- ExtremeSwitching
5420F-8W-16P-4XE—ExtremeXOS 31.3 and
later.
- ExtremeSwitching
5420F-24P-4XE—ExtremeXOS 31.3 and
later.
- ExtremeSwitching
5420F-16MW-32P-4XE—ExtremeXOS 31.3 and
later.
- ExtremeSwitching
5420F-16W-32P-4XE—ExtremeXOS 31.3 and
later.
- ExtremeSwitching
5420F-48P-4XE—ExtremeXOS 31.3 and
later.
- ExtremeSwitching
5420F-48P-4XL—ExtremeXOS 31.3 and
later.
- ExtremeSwitching
5420M-16MW-32P-4YE—ExtremeXOS 31.3 and
later.
- ExtremeSwitching
5320-48P-8XE—Switch Engine 31.6 and
later.
- ExtremeSwitching
5320-24P-8XE—Switch Engine 31.6 and
later.
- ExtremeSwitching
5320-16P-4XE—Switch Engine 31.7 and
later.
- ExtremeSwitching
5320-16P-4XE-DC—Switch Engine 31.7 and
later.
- 4220-12P-4X—Switch Engine 32.7.1 and
later.
- 4220-24P-4X—Switch Engine 32.7.1 and
later.
- 4220-48P-4X—Switch Engine 32.7.1 and
later.
- 4220-4MW-8P-4X—Switch Engine 32.7.1
and later.
- 4220-4MW-20P-4X—Switch Engine 32.7.1
and later.
- 4220-8MW-40P-4X—Switch Engine 32.7.1
and later.
- ExtremeSwitching 5520-24W—ExtremeXOS 31.1 and later.
- ExtremeSwitching 5520-48W—ExtremeXOS 31.1 and later.
- ExtremeSwitching 5520-12MW-36W—ExtremeXOS 31.1 and later.
- ExtremeSwitching 5420F-8W-16P-4XE—ExtremeXOS 31.3 and later.
- ExtremeSwitching 5420F-16MW-32P-4XE—ExtremeXOS 31.3 and later.
- ExtremeSwitching 5420F-16W-32P-4XE—ExtremeXOS 31.3 and later.
- ExtremeSwitching 5420M-24W-4YE—ExtremeXOS 31.3 and later.
- ExtremeSwitching 5420M-16MW-32P-4YE—ExtremeXOS 31.3 and later.
- ExtremeSwitching 5420M-48W-4YE—ExtremeXOS 31.3 and later.
- ExtremeSwitching 5720-24MW—Switch Engine 32.1 and later.
- ExtremeSwitching 5720-24MXW—Switch Engine 32.1 and later.
- ExtremeSwitching 5720-48MW—Switch Engine 32.1 and later.
- ExtremeSwitching 5720-48MXW—Switch Engine 32.1 and later.
- 4120-24MW-4Y—Switch Engine 32.7 1 and
later.
- 4120-48MW-4Y—Switch Engine 32.7 1 and
later.
- 4220-4MW-8P-4X—Switch Engine 32.7 1 and
later.
- 4220-4MW-20P-4X—Switch Engine 32.7 1 and
later.
- 4220-8MW-40P-4X—Switch Engine 32.7 1 and
later.
